Digital I/O
Accessing I/O
Is there any way to access the digital IO on the sbRIO-9637 without having to use LabView?
(3,096 Views)
How did you want to access it?
Setu P.
Applications Engineering
(3,056 Views)
I want to access it using the CPU but I cannot do that because the FPGA is connected to IO and I don't want to program the FPGA using LabView. Is there a default C API available online that I can use to access the IO?
(3,039 Views)
Bump.
Anyone have thoughts on this?
I'm working with awsomeer on the same project, and it would be really nice to access the I/O without having to write much LabView. Our team has a lot of C/C++ experience but very little LabView experience. We're using the NI Linux Real-Time toolchain to write our application in C++.
(3,016 Views)
We would also like to access the I2C and SPI buses
(2,980 Views)
I think this is what you are looking for.
https://www.ni.com/en/support/documentation/supplemental/09/introduction-to-the-fpga-interface-c-api...
Let me know if you have questions.
Setu P.
(2,970 Views)
Thanks for the reply!
I did see that page, but my understanding was that we would have to write a custom labview wrapper for the I/Os we want to use and then generate a C API to call functions in our custom VI. Is that correct?
Is there a default VI running on the FPGA that we can access from the CPU without writing our own labview code?
(2,961 Views)
