Digital I/O
Adding an air actuator to UMI-777R
I am doing my senior design project for college and am making a testing fixture for fishing reels. It consists of two motors and one air actuator. I have got it all hooked up and both motors working the actuator is wired into the digital io pin 8 which is output 0. The air valve just takes a 24 v direct to energize. How do I comunicate to the output I have max and labview up on front of me any and all help is needed
(3,637 Views)
Umi-7774
(3,636 Views)
Are you asking how you can control the actuator from the DIO pin you have it connected to using LabVIEW?  Do you already have the actuator exergized with a 24VDC power supply?  What is the control scheme for your actuator?
(3,562 Views)
