Digital I/O
Adlink USB 7250
Hello Forum,
I know this is not an Adlink forum, but can anybody help me?
I am using an Adlink USB7250 DAQ together with labview 12.
I'm trying to control a relay with the adlink in setting the DO Port to high and after 2ms change it to low. This works fine, but if I put a for loop around it I get an error  "No channel is enabled for this operation.". The error occours after the first run.
Does anybody have an idea?
(6,521 Views)
Hi  @Notrix83
I do not have answer to your query, but i have a question for you 😛
I am trying to communicate with Adlink 7250 using LabVIEW. But device not getting detected.
Can you please share how did you get your project going with Adlink7250?
Many thanks in advance.
(3,062 Views)
