Digital I/O
Analog output/input on 6519?
Hello there
I was wondering whether the NI 6519 has also an analog output/input channel (for communicating with a rs232 device). I couldn't find anything in the datasheet, so maybe there is no analog I/O.
Thanks for your help!
(3,071 Views)
It's digital only and even if it had an analog output, I don't understand how you would use it to communicate to RS-232. The digital I/O on your board would be a lot closer to doing this type of communication but even that wouldn't work. A USB->RS-232 converter is pretty cheap if you don't have a serial port on your pc.
(3,069 Views)
