Digital I/O
Any way to get >20MHz digital out on crio 9082?
We already have a cRIO 9082 and REALLY want to generate a 25 MHz (manchester) signal with it (in order to sync with another device that needs the 25 MHz manchester).  I understand 20 MHz is the highest rate for a dio module.  Are there any tricks or third party solutions that could get us to 25 MHz?
We're starting to think about external circuits; I'm not fluent in phase locked loops (I'm from the software side) but it seems like it would be difficult given the manchester signal.
Steve
(5,878 Views)
The 9402 module has a 20 MHz maximum clock rate, which, as you stated, is the fastest rate for a DIO module. However, I have done seen some benchmarking before using a CompactRIO 9082 with a 9402 module that was capable of generating a clock signal with a 30nS period (~33.3 MHz). This was done using a 200 MHz derived top-level clock and the FPGA target cannot use a clock faster than 200 MHz for it's top-level clock.
Keep in mind that this is by no means official, it was just some random benchmarking that I done before. Just wanted to state this since it is not an official specification of the 9402 at all. Hope this helps though!
dK
(5,861 Views)
Heck ya that helps! I can't imagine much of a better comment 🙂
I know it's unofficial so we will definitely test it out, Thanks for sharing!
Steve
(5,858 Views)
Woke up last night thinking maybe you were talking about switching at 33.3 MHz.  Could you confirm that you were switching at 66.6 MHz, resulting in a 33.3 MHz clock?   Thanks!
Steve
(5,844 Views)
Yes it was a clock (not switching) running at a 30 ns period (~33.3 MHz).
dK
(5,840 Views)
