Digital I/O
Application init error
Hello
I am a programmer in VisualC++ using the NI-DAQmx6501 device (USB connection).
First, i installed the NI software that come with the device on CD.
Then, in my MFC application i include NIDAQmx.h file and link with NIDAQmx.lib file.
My application Read/Write successfully from/to the device in the PC where NI software is installed.
The problem is when i try to run on another PC (after adding all the requested DLL's to the application directory) i receive windows error: Application failed to init properly (0xc0000142)...."
What should i do to run my application on other PC without an installation of NI software?
Shmulik
(3,432 Views)
@Shmulik wrote:
Hello
Shmulik
Hi Shmulik,
You need to use the installer to get DAQmx to work.
Jeff
(3,428 Views)
