Digital I/O
Arduino - LDAC - SPI - urgent!!
I am completely new in labview coding. I have an arduino nuo chip, connected with a DAC converter, AD5504, Analog Devices, and an operational ampli er (OPA551, Texas Instruments) circuit to generate voltage output for piezoelectric firing. The wanted voltage output ranges in 0 - 60 v. However, under my coded program, there is either no voltage output or very low output, like 1.5 V. In the rare case of low voltage output, the voltage is not changable, by applying either digital write () or PWM write pin (). In the attached vi it gives error 5004 at running. Please look through my coding and help me figure it out.
This is urgent so a quick favor is needed.
Thanks.
(5,762 Views)
(5,750 Views)
