09-17-2018 02:20 PM - edited 09-17-2018 02:21 PM
Hi all,
I've bought a PCIe-6341 DAQ board, a BNC-2090A block connector and 2 SH68-68-D1 68-pin cables. My objective is to use the BNC-2090A to read in simultaneous signals coming from some BNC connectors (among the AI-0 to AI-15 connectors), the frontal 68 pin connector and from the spring terminals block. The final goal is to output all signals from the rear 68-pin connector of the BNC-2090A to the PCIe-6341 DAQ board. Is it ok to do that? Sorry if this is a basic question but I have just started using such systems.
Best regards.
09-18-2018
11:10 AM
- last edited on
10-11-2024
05:47 PM
by
Content Cleaner
The first place to get some help would be the NI Example Finder. You can access this from the main LabVIEW startup menu » Help » Find Examples. If you search for synchronization analog input you can find an example to show you how to implement that.
Since you mentioned you were new to these systems, I might suggest checking out the Getting Started with NI-DAQmx: Main Page. I think it would be a great reference to help you get started programing in LabVIEW with DAQmx!
Here are a few further reads for more information regarding synchronization:
This white paper that explains the concepts of synchronization and how to do it with NI software and hardware. I think this would provide you an in depth look on configurations, considerations and design.
In the last section of this white paper, SC Express and X Series, explains some considerations when attempting to synchronize on X series devices.
Cheers,
Mike P.
09-25-2018 08:34 AM
Thank you very much for the info. I just wanted to know whether it would work. By knowing it will, now I will invest time on learning how to make it function. I really appreciate the feedback.
Best.
10-02-2018 11:23 AM
I couldn't achieve what I needed. My main question now is: Is it possible to configure the BNC-2090a in a way that when 2 cables are connected to the frontal and rear 68-pin socket each, it does NOT work as a pass-through? My final goal is to get the signal of 4 pins (2 pairs signal + ground) of the 68-cable sending the inputs and output it to the DAQ-board. Of course I could cut the 68-pin cable and solder BNC connectors to the 4 specific wires and connect them to two AI channels in the BNC-2090a but I was looking for sth more "elegant".
Best.
10-03-2018 02:57 PM
Internal connections between pins is possible, but it is dependent on the type of I/O. But I think it would easiest to get a BNC to connector block converter.
