Digital I/O
Best timing method for Digital Output for NI PXI 6527?
I am trying to improve the timing reliability of changing the digital output values for a NI PXI 6527. I have attached an image of a snippet of code demonstrating my current method of:
-writing the output values
-waiting until time has expired
-writing new output values, and so on.
Unfortunately, I find this method does not have very reliable timing, and my switches do not always turn on and off when they should.
I was thinking that a better approach was to have some kind of "script" that updated the output values at a specified rate. I thought the example VI "Digital - Continuous Output" was a good starting point, however, I continue to get the following error:
Possible reason(s):
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: SampTimingType
Requested Value: Sample Clock
Possible Values: On Demand, Change Detection
Task Name: _unnamedTask<2D>
I am using the OnboardClock as my Sample Clock Source. In the VI description, it says it is supported by PXI 6527, but I can't seem to make it work.
Any help on:
1. Improving the timing reliability of changing digital output values or;
2. Resolving the above error when executing the "Digital - Continuous Output" VI with a NI PXI 6527 and using the OnboardClock.
Would be greatly appreciated!
Ian
(2,647 Views)
itoma054,
Does the original code that you were using use the same clock?
I found this forum post where someone has a similar issue: https://forums.ni.com/t5/Multifunction-DAQ/Error-200077-occurred-at-DAQ-Assistant/td-p/845960
Just to see if the clock is the issue, try changing the Write in the example to 1 sample, making it On Demand.
Also, I assume the Channel Line(s) input in the example is properly set to a channel on that board?
MVC
(2,618 Views)
