Digital I/O
Boardcode of PCI-6503 and NI 6519
What code is returned by the Init_DA_Brds NI-DAQ function call for the NI PCI-6503 and NI PCI-6519 devices?
(3,519 Views)
The board code of the PCI-6503 is 256 (see documentation for Init_DA_Brds). The NI 6519 is not supported under traditional DAQ. Thus the board code is not relevant as Init_DA_Brds doesn't work for this board. You can use NI-DAQmx attributes to read the board type as a string (see also this knowledge base article).
I hope that helps,
Jochen Klier
National Instruments Germany
(3,509 Views)
Yes, it helps.
Thank you, Jochen
(3,505 Views)
