Digital I/O
Boolean to single boolean array
I am using DAQmx to send digital output for a line (not a port).  The input requires a boolean array of one element.
I want to use a T/F boolean from an On/Off button as inpuit to the DAQmx digital out.
How does one get a Boolean to a 1-D, single member, boolean array?  (I can make an 8 or 16-member array, but the DAQmx does not take it)
My version is 8.6.
This seems like a very common thing to do and I'm just not getting it.
Thanks you,
MRMDry
(3,520 Views)
First, if you want to use a single Boolean, then the DAQmx Write Digital>Single Channel>Single Sample>Boolean will allow you to wire a Boolean directly and you do not need an array. Second, if you don't want to change the DAQmx Write, then just wire the Boolean to the Build Array function.
(3,510 Views)
