Digital I/O
Buffer Control Regenerate Data - DAQCard 6533
I am trying to investigate the use of the 'allow regeneration' option of the BufferControl.vi (used in the DIOStart.vi).  I have attached a simple program that allows the user to select the data they want to output, which uses all 4 ports of the DAQCard 6533.  I want to have this data output The program should have the BufferControl set to allow regeneration of the data.
My question is - where do I loop the program?  Do I need to put another DIOWrite after the DIOWait?  I have tried several things, but keep getting errors.  It seems as if it should be fairly simple, but maybe I need a better understanding of how the buffer works.
Thanks in advance for your help.
(3,340 Views)
Hi Operative,
Typically, the loop goes after the start and before the clear.  What errors are you receiving?  Does anything change when you implement the loop?
h_baker
(3,319 Views)
