Digital I/O
[C#] Digital Edge counting, Linear position, Read Buffered
I'm trying to read buffered data from a NI USB-6210.
My goal is to sample the linear position(edge count) and the time the edge occurred.
For the time I use the internal sample clock.
But I don't get it to work. What am I doing wrong?
Thanks for your help!
My code for now:
namespace LinearPositioningBuffered
    public partial class MainWindow : Window
        private Task aiTask;
        private Task counterTask;
        private Task runningTask;
        private CounterReader counterInReader;
        private AnalogMultiChannelReader reader;
        private AsyncCallback asyncCB;
        private double[] data;
        private int BufferSize;
        public MainWindow()
            InitializeComponent();
            uxStopButton.IsEnabled = false;
            asyncCB = new AsyncCallback(CounterInCallback);
        private void ReadChannelBuffered()
            int sampleRate = 1000;
            BufferSize = sampleRate * 10;
            bool zIndexEnable = false;
            double zIndexValue = 0;
            double intialPosition = 0;
            double distPerPulse = 1;
            try
                aiTask = new Task();
                // create a channel
                aiTask.AIChannels.CreateVoltageChannel("dev2/ai0", "", (AITerminalConfiguration)(-1), -5, 5, AIVoltageUnits.Volts);
                // Configure timing specs
                aiTask.Timing.ConfigureSampleClock("", sampleRate, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, 2000);
                // Verify the task
                aiTask.Control(TaskAction.Verify);
                counterTask = new Task();
                counterTask.CIChannels.CreateLinearEncoderChannel("dev2/ctr1", "LinearPosition", CIEncoderDecodingType.X1,
                    zIndexEnable, zIndexValue, CIEncoderZIndexPhase.AHighBLow, distPerPulse, intialPosition, CILinearEncoderUnits.Meters);
                //Configure timing
                counterTask.Timing.ConfigureSampleClock("/dev2/ai/SampleClock", 0, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, BufferSize);
                counterTask.Control(TaskAction.Verify);
                runningTask = counterTask;
                counterInReader = new CounterReader(counterTask.Stream);
                counterInReader.SynchronizeCallbacks = true;
                counterInReader.BeginReadMultiSampleDouble(BufferSize, asyncCB, counterTask);
                // Read the data
                reader = new AnalogMultiChannelReader(aiTask.Stream);
                reader.ReadSingleSample();
                uxStartButton.IsEnabled = false;
                uxStopButton.IsEnabled = true;
            catch (DaqException exception)
                counterTask.Dispose();
                runningTask = null;
                MessageBox.Show(exception.Message, "ReadChannelBuffered");
        private void CounterInCallback(IAsyncResult ar)
            try
                if (runningTask == ar.AsyncState)
                    data = counterInReader.EndReadMultiSampleDouble(ar);
                    for (int idx = 0; idx < data.Length; idx++)
                        Console.WriteLine(string.Format("{0}: {1}", idx, data[idx]));
                MessageBox.Show(exception.Message, "CounterInCallback");
                Stop();
        private void Stop()
            runningTask = null;
            uxStartButton.IsEnabled = true;
        private void uxStartButton_Click(object sender, RoutedEventArgs e)
            ReadChannelBuffered();
        private void uxStopButton_Click(object sender, RoutedEventArgs e)
            Stop();
Message 1 of 1
(5,519 Views)
