Digital I/O
CVI HSDIO (NI6541) acquire with external strobe
I agree that a pattern match is probably your best bet. You can setup the trigger, start the acquistion, call "wait until done" and after you return from it, you know that a poulse has arrived and you can proceed with generation.
Just FYI: if you happen to have a 653x card laying around; these boards have a "Change detection" timing mode which works at relatively slower speeds, but would be the ticket for this type of application.
Good luck with your project.
Juan Carlos
Message 11 of 11
(1,324 Views)
