Digital I/O
CWDI control on a PCI-MIO-16XE10 card
Can one use the CWDI control on a PCI-MIO-16XE10 card?
(3,400 Views)
Matteo,
The CWDI is designed for NI boards that have timing capabilities with their digital lines, such as the NI-6533/6534. Your PCI-MIO-16XE10 uses the DAQ-STC digital control chip, which only supports static digital IO. Therefore you cannot use the CWDI control since it is made for HW timed digital applications.
You utilized your board�s digital lines; CDDIO or NI-DAQ function calls will be the best option.
Hope this helps.
Kevin R
(3,400 Views)
OK, thanks for letting me know. I will use the DIO command in combination with a simple timer.
Best
-Matteo
(3,400 Views)
