02-19-2007 07:47 AM
02-20-2007
10:37 AM
- last edited on
02-07-2024
08:42 AM
by
migration-bot
Hi ejones,
The 6514 has 32 input lines and 32 bit output lines. You can configure all 32 input or output lines on the 6514 to act as a single port by creating a digital 32 bit port and reading or writing a 32 bit integer. The NI-DAQmx C Reference Help is a very useful file which contains all DAQmx function calls and can be found under Start » Programs » National Instruments » NI-DAQ.
