07-22-2005 01:03 PM
07-25-2005 06:38 PM
Please let me know if you have any questions. Have a great day!
Sincerely,
Marni S.
11-08-2005 03:56 PM
Hey,
To further add to Mari's answer, the power-up state of the USB-6501 is always a high impedance input. Each input is tied to a weak pull-up resistor and the DAQ board does not drive it either signal high or low. If it is necessary to set the power-up state of a digital line, other DIO boards do support that option. For example, the power-up state of the PCI-6503 and USB-6709 can be set in MAX. For future reference, the data sheet list usually lists what power-up states are available for a specific board.
David Hall
02-19-2006 03:41 AM
02-20-2006 01:26 PM
Hi Domingo,
As David said, the power-up state of the USB-6501 is always high impedance. This means that the digital lines are not driven high or low. Also, the properties option is MAX is always disabled for this device. National Instruments makes other hardware with programmable power up states if you need this functionality.
Hal L.
03-05-2006 11:55 PM
03-07-2006 07:28 AM
04-04-2006 04:13 PM
04-05-2006 10:34 AM
07-10-2006 05:45 AM
