Digital I/O
Can I control output voltage of USB-6501 Digital I/O?
I thought that Vdd, Supply Voltage has issue by restricted under 3.6V.
You mean that it will be okay when I use active drive mode, right?
Message 11 of 13
(420 Views)
Accepted by topic author junhong0708
As per your RF Switch datasheet it can handle up to 5.5V signals on the control pins. Any way, you can still play safe by using Active Drive mode and thereby be within 3.6V on 6501.
Santhosh
Soliton Technologies
Message 12 of 13
(414 Views)
Thank you very much for your help. I saw a way out of long-standing difficulties.
Message 13 of 13
(402 Views)
