Digital I/O
Can I power two separate devices using one NI 9474
I have written a code to use port0/line0 of the NI 9474 to supply current to a Thermoelectric heater which I pulse on and off using LabVIEW.
Now, I want to power one more thermoelectric heater and heat them both to two different temperatures (so their controls in LabVIEW will be different cases).
When I connect it to another port0/line x or even to a different NI 9474 (I have an extra), I get power to only one heater and the other doesn't function.
I am connecting all my modules to a cDAQ-9178 (can hold 8 modules).
Is there a way around this?
(3,865 Views)
If I had to take a guess, I would say that you need a 24V power supply that can supply more current.
(3,860 Views)
I am using a 12 V, 8.5 A supply. I think It may be enough. I remember reading that each chassis has only onw hardware clock. Will that affect my ability to run two separate digital o/ps from one chassis?
(3,857 Views)
This KB might help answer that
How Many Different Tasks Can I Run on My Multifunction DAQ Card?: http://digital.ni.com/public.nsf/allkb/4118E8CE24F4101786257EAB00597A93
Daniel Parrott
Software Product Marketing - Data Management & LabVIEW
(3,832 Views)
