Digital I/O
Can I use SCC-DI01 modules with a PCI-6533 device?
I am looking into performing buffered acquisition of various digital signals using a PCI-6533 device. Can I use SCC-DI01 modules with this device? If so, would this be via the SC-2345 Carrier? The manual seemed to suggest is was only compatible with E-series devices?
Basically, I want to monitor 32 digital channels and will have a mixture of 5V and 24V signals.
Many thanks,
Douglas
(3,293 Views)
Hi Douglas
Could you please clarify where the manual suggests that the module is only compatible with an E series board (is it because only an E series board is referenced in the manual)?
I can't find any information stating which devices are/aren't supported by the SCC-DI01, but I will continue to investigate and keep you posted with my progress.
Kind Regards
Stuart R
(3,293 Views)
