Digital I/O
Can I use my PCI-6503 with Matlab?
I want to know if the PCI-6503 card is compatible with Matlab?
(3,317 Views)
Greetings,
The PCI-6503, as well as all of our other data acquisition boards, ships with the NI-DAQ driver. This driver is tightly integrated with our software packages such as LabVIEW, LabWindows/CVI, Measurement Studio, etc. However, the driver also provides a DLL interface that can be used with any other development environment which has the ability to make calls into a DLL. While it is possible to control your hardware via the DLL interface, I would definitely suggest that LabVIEW would be much, much simpler and faster.
To check whether Matlab has the ability to make calls into a DLL, and whether there are any issues with making calls into a DLL, please contact The Mathworks Technical Support.
When making calls into the NI-DAQ Driver DLL you wi
ll benefit from the following Function Reference Manual.
NI-DAQ Function Reference Manual for PC Compatibles
http://digital.ni.com/manuals.nsf/websearch/1630A0B68738B269862567C1007A2912?OpenDocument&node=132100_US
Justin Britten
(3,317 Views)
