Digital I/O
Can PCI 6534 output 32-bit sample at a time
Hi, sorry to bother if not intersted.
I was using C++ and NI-DAQmx to do an externally-triggered pattern generation on PCI 6534. Using the following code, I was able to generate an array of 32-bit samples at a time:
uInt32 DataArray[Nsamples];
DAQmxErrChk (DAQmxWriteDigitalU32(taskHandle,Nsamples,FALSE,Timeout,DAQmx_Val_GroupByScanNumber,DataArray,&written,NULL));
When I switched to NI-DAQ, it seems that I can group all data with groupsize=4, but in the following respective function, the datatype of "piBuffer"canonly be "i16" (16-bit int). Do I have to re-calculate all my data and split into two groups?
DIG_Block_Out(iDevice, iGroup, piBuffer, ulCount);
If one does this, will it be able to output 32-bit smaple at each defined clock cycle or it needs two cycles?
Thanks.
(3,541 Views)
In case one needs to know why I need to downgrade from DAQmx to DAQ:
we have a old computer with other NI cards, DAQ driver and Labview 6.1 installed, it takes less time to downgrade DAQmx than upgrade all others.
(3,538 Views)
Accepted by topic author eLions
kxz,
Thanks for posting on the NI Forums. I believe there are a couple of suggestions for this, you will have to forgive me somewhat we don't get a whole lot of questions on Traditional DAQ much anymore.  I believe that you will have a couple of options in your case:
1) the DIG_Out_Prt function that can be called four times (once for each port) with a pattern that you want or,
2) you can call the DIG_Block_Out function, now the buffer input will be an input with two arrays, each of 16 elements. You will need to set your group size as 2 (2 groups of 2 ports) or as 4 (4 groups of 1 port), DIG_Block_Out writes data from the lower 8 bits of buffer [0] to the lower port (port 0 or port 2) and data from the upper 8 bits of buffer [0] to the higher port (port 1 or port 3). If group size is 4, DIG_Block_Out writes data from buffer[0] to ports 0 and 1 and data from buffer[1] to ports 2 and 3.
Overall, we strongly suggest using DAQmx for your programming, but we do have good documentation on all of the C functions within the Traditional NI-DAQ (Legacy) Help. You can normally find this file under Start >> Programs >> National Instruments >>  NI-DAQ >> Traditional NI-DAQ Function Reference Help. This includes all the documentation for our text-based functions. Thanks!
Aaron W.
CLA, CTA and CPI
(3,510 Views)
