Digital I/O
Can create DAQmxCreateDIChan and DAQmxCreateDOChan in the same task.
       Can we create DI and DO channel in the same task? Below is my coding but if used the same task it show error message.
         Error Msg  =
Task cannot contain a channel with the specified channel type, because the task already contains channels with a different channel type.
Create one task for each channel type.
Code =
' Create the DAQmx task.
DAQmxErrChk DAQmxCreateTask("", vTaskHwnd)
' Add a digital input channel to the task.
DAQmxErrChk DAQmxCreateDIChan(vTaskHwnd, DIPortAddress, "", DAQmx_Val_ChanForAllLines)
DAQmxErrChk DAQmxCreateDOChan(vTaskHwnd, DOPortAddress, "", DAQmx_Val_ChanForAllLines)
'Start the task running, and read from the digital lines.
DAQmxErrChk DAQmxStartTask(vTaskHwnd)
vTaskIsRunning = True
Thank you very much.
(4,109 Views)
The error message already answered your question: no you can't have DI and DO channels in the same task.
Ben64
(4,077 Views)
Just use the same task to write and read.
using (Task digitalWriteTask = new Task())
                    //  Create an Digital Output channel and name it.
                    digitalWriteTask.DOChannels.CreateChannel("Dev1/po​rt0", "port0",
                        ChannelLineGrouping.OneChannelForAllLines);
                    //  Write digital port data. WriteDigitalSingChanSingSampPort writes a single sample
                    //  of digital data on demand, so no timeout is necessary.
                    DigitalSingleChannelWriter writer = new DigitalSingleChannelWriter(digitalWriteTask.Stream​);
                    writer.WriteSingleSamplePort(true, (UInt16)this.numericEdit1.Value  );
                    //  Create the reader
                    DigitalSingleChannelReader reader = new DigitalSingleChannelReader(digitalWriteTask.Stream​);
                    //   Read back the value
                    this.textBox1.Text =  reader.ReadSingleSamplePortByte().ToString();
Curt
(3,993 Views)
No you can't.
(3,879 Views)
Yes you can. It works!
Curt
(3,875 Views)
Curt
The answer is no you can't. Curt I agree that your code work but it is not the same thing. Your task only have DO channels that outputs data to a stream. Your reader is reading data from this stream so it is more like an echo mode, it is not reading input data from a physical channel.
Ben64
(3,870 Views)
