Digital I/O
Can i access ISA-Cards with the MH-DDK
ok the basic problemis the following (i posted that already & thx to todd..)
i want to access the 8253 timer on a (ISA) PC-DIO-96 card, which is not possible from NIDAQ.
now i want to write my own device driver (i dont actually want, but i guess theres no other way)
the MH-DDK is, afaik, based on VISA, which afaik is supposed to work with PCI/PXI cards.
now - how do i access non-PCI (ISA) cards with the DDK?
thx
(3,174 Views)
Greetings,
It is not possible to use the Measurement Hardware DDK with your PC-DIO-96. You will need to use traditional register-level programming. The user manual for your board has a section that describes this process. I have included links to these manuals below (I was not sure if your PC-DIO-96 is PnP or not).
PC-DIO-96/PnP User Manual
PC-DIO-96 User Manual
Good luck with your application.
Spencer S.
(3,174 Views)
My apologies for this late reaction, but if you have an ISA card (in my case, a Lab-PC-1200), and are running on Win2000 and NIDAQ isn't sufficient enough, you still have to write your own driver. So, what can I use in stead of the ddk? Or where can I find information about writing your own driver for an ISA card?
(I used assembler RLP in win98, but now we are changing over to win2000)
thanx in advance......
greetz
(3,174 Views)
