Digital I/O
Can i use PCIe-6535B/36B/37B onboard connector to reach DIO pins?
I will use PCIe DIO boards. I didn't find any document about this connector.
(5,427 Views)
The PCIe-6535B is a Digital I/O card. I have included the extended specifications below.
http://www.ni.com/pdf/manuals/374373g.pdf
The connection I believe you are referring to is a RTSI connection. More information about this type of connection can be found here: http://digital.ni.com/public.nsf/allkb/A120195AAAA9222A86256C69007C8B27
I hope this helps!
(5,395 Views)
Thanks for your answer.
(5,387 Views)
