Digital I/O
Can't compile with SbRIO 96006
Hi, I'm woriking with a sbRIO 9606, according with the tables 1 and 2 (https://www.ni.com/en/support/documentation/compatibility/19/compatibility-between-xilinx-compilatio...), i have installed Vivado 2015.4 but when I try to compile my VI, it says "The compile worker cannot perform the compilation. The compile worker may be configured incorrectly for this compilation or it may be in an error state.". I have been using the cloud service but my acc expired. Could someone tell me hot to configure the compiler or if im installing the incorrect version. Thank you.
(2,940 Views)
I have installed Labview 2017, FPGA Module 2017, Compact rio 2017 and NIRIO 14.5
(2,916 Views)
