Digital I/O
Can't locate driver error 10240 - NIDAQmx 9.7 for Card PCI 6527
Hello dear partners,
I'm using NI DAQmx 9.7 in a machine hosting a Windows 7, but always when I tried to run the application I got this error.:
CAN'T LOCATE THE DRIVER ERROR 10240
I can see that it happens when I tried to call this function.: DIG_Out_Line(short device,
                               short port,
                               short line,
                               short lineState)
from dataacq.h file
Previously I was using the driver NI DAQ 7.4.4 (Legacy) in a machine hosting a Windows XP, but I believe it doesn't work very well on Windows 7 even running in compability mode.
Does you have any idea why could I'm facing this problem ?
Best Regards
Josias Junior
(6,463 Views)
Hi!
I Have the same problem!
- NI-DAQmx 9.7.5
- Windows 7 Home Basic
and the DIG_Out_Line reply an ERROR:
Justin Morales
Best Regards...
(6,029 Views)
Is important to know your LabVIEW version.
Which version are you using?
Rita Souza
Engenharia de Aplicações
National Instruments Brazil
(6,019 Views)
I'm using an Application compiled in LabWindowsCVI 2009
I Find this topic:  http://digital.ni.com/public.nsf/allkb/8EC9E81C3DE4E619862573930083BD7A
"Traditional NI-DAQ (Legacy) 7.5 Beta"
I will try to intall it and see how it works, i will keap in touch on the progress...
Best Regards..
Justin Morales
Best Regards...
(6,010 Views)
Is not necessary make this. Your Windowns and your PCI are compatible with NI-DAQmx 9.7 but, maybe you installed you LabWindowns on default module and forgot of install something.
1º Step - Run a EXAMPLE and see that everything will work or if the same problem is display for you.
2ª Step - With the same problem appear send me your MAX Report.
    - Open MAX
    - Click on "File"
    - "Create a Report"
    - Send to the file to Technical Support
Regards
Rita Souza
(5,996 Views)
Hello Josias! How you doing?
Rita Souza
(5,994 Views)
