Digital I/O
Can the DIO lines on the NI-8452 be used as CS lines?
I need to have more than the 8 CS lines on the NI-8452.  Can the DIO lines be used as CS lines?
Thanks.
(2,728 Views)
Hi Monkeydoo,
I think that there is no problem if you use a DIO line for this purpose. The only requirement would be to use a Digital Ouput task and set it to a low state if you want to communicate with the device or a high state if you don´t want to.
Resultado de imagen para spi protocol diagram
(2,692 Views)
