Digital I/O
Can the NI-6534 internal clock be made external so other devices can see it?
I am using an NI-6534 Digital I/O card to output 16 bit words (originally from a data file) to an external device - a star occultation detector.
I wrote code that successfully writes the data out Port 0 using the internal clock on the 6534 card.  We have to write the data out in a periodic way.
However, the external device needs to read in the data and relies on a clock external to it to do that. So I'd like to present the 6534 internal clock onto one of the output lines.
Is this possible? If so, what calls/parameters woudl you use?
I'm using NIDAQ 8.02 on an OpenSUSE 11.3 system.
thanks
Gregg
(5,932 Views)
Hi Gregg,
I believe that you can export your timebase to your other device.
Do you know whether your 6534 is a PCI form factor or a PXI? If your device is a PCI card, you can export your timebase or sample clock through the RTSI lines. If the device is a PXI card, the 6534 uses PXI trigger line 7 as the RTSI clock line.
In order to see what specific lines you can route your timebase through, I would refer to the Device Routes Tab in MAX (Measurement and Automation Explorer). This is what it looks like:
I also found that page D-10 of the manual also talks about routing clock sources. The manual can be found here: https://www.ni.com/docs/en-US/bundle/371464d/resource/371464d.pdf
Hopefully this information is helpful!
Leah
(5,911 Views)
Looks like the clock is output on the REQ pin. I certainly know our PXI 6533 implicitly outputs the clock on a pin without any routing required. Else you can use route signal to explicitly route the signal as the post above mine indicates.
(5,822 Views)
