Digital I/O
Change PFI output voltage
Is there a way to change the voltage output for the PFI on the 6259 card?
Andy
(3,470 Views)
Hello Andy,
Thank you for using NI forums.  The PFI lines on the 6259 support TTL logic, which means the output is either 0 or 5V.  What output are you hoping to achieve?  You may want to look into using a voltage divider.
(3,455 Views)
Thanks,  That's what I thought.   I have to suply 3.3V and 2.2V and I was hoping there was a way to prgram the output.  But I'll just use resistors.
Andy
(3,451 Views)
