I need check an input connected to an emergency button and stop running vi, some one has an example that I can use ??? I will appreciate your help, thanks
Assuming that it's a TTL signal, you just need a single DAQmx Read set for single sample Boolean and wire the output to your while loop's termination terminal. A DAQ Assistant set for the same would work as well.
