Digital I/O
Communication between Mitutoyo Digimatic gage and com port
I am having difficulty configuring my Mitutoyo Digimatic gage connected through a MUX-10, with my COM port.
(4,084 Views)
David,
While I personally lack experience with this device I found a discussion post that may help out:
http://forums.ni.com/ni/board/message?board.id=170&message.id=4982&requireLogin=False
Are you attempting to program in LabVIEW? What types of communication issues are you seeing?
Craig H.
NI Applications Engineering
(4,073 Views)
Included with labview 6.1 there is a serial communication vi that with some minor modifications will talk to your gauge.
here is a copy of a modification i made fairly quick to talk to a mitutoyo gauge. Please note this vi also interfaces with a force gauge so you may want to delete that portion of the code if you do not have an E series card installed. This example also saves data to a text file.
Hope this helps.
(4,064 Views)
