Digital I/O
Communication with the 9100 BK of beckoff
How can I test the communication with the module BK 9100?
I am trying to activate digital outputs without success, through TCP communication.
(4,532 Views)
I think that you should contact the builder of your device in order to get a solution to your issue.
(4,510 Views)
Hello
Thank you for the suggestion.
However, I was able to test.
Just do the ping the configured IP
Now, I can already switch On the digital output from the BK9100.
I just have some problems, because i have 40 outputs.
Now only missing to read the analog inputs
(4,502 Views)
c-m wrote:
Hello
Would you please be so kind to tell me (us) how you did it 🙂
Because I managed to see variations in TwinCAT System Manager according to LabVIEW controls but no communication toward the BK9100 (com led continously dead on BK9100) thus also no change in digital outputs on KL2408 module 😞
Did you use ActiveX, or DLL, or maybe send direct Modbus TCP telegrams??
Did you use TwinCAT System Manager to map I/O or not??
Can you share some vi's? (I use LV 8.5 ;))
See this thread I started... ...
(4,112 Views)
I am trying to communicate to BK9100. Can you please share those VI's with me. It will be helpful for me.
 ganeshkumar.natrajan@gmail.com
(3,595 Views)
