Digital I/O
Compact DAQ数字模块选型求助,5V和5VTTL的区别
我需要在计算机上读取编码器的输出信号,再通过NI CompactDAQ数字模块输出为0~5V高低电平信号(原编码器输出信号,信号类型为5VTTL单方波,见附图).我在官网上查找C系列数字模块选型,想请问“数字I/O逻辑电平”这栏,5V和5VTTL有什么区别?我应该选哪种?
(922 Views)
@johnabc1234567 wrote:
I need to read the output signal of the encoder on the computer, and then output it as a 0~5V high and low level signal through the NI CompactDAQ digital module (the original encoder output signal, the signal type is 5VTTL single square wave, see the attached picture). I am on the official website I searched for the selection of C series digital modules on the Internet, and would like to ask the column of "digital I/O logic level", what is the difference between 5V and 5VTTL? Which should I choose?
5V and 5VTTL are essentially the same thing.
There are a few types of TTL logic. Among them, the most common ones are 5VTTL and LVTTL (3.3V CMOS). See Logic Levels
https://tmesystems.net/
(903 Views)
