Digital I/O
Computer / nuDrive connection
I want to connect a stepper motor to the computer via nuDrive(Model: nuDrive-2SX-411).
So I did the followings.
- I installed PCI device to the computer
- I installed Labview software and NI drivers (DAQmx, VISA, 488.2, Motion)
- I connected the stepper motor (phytron ZSS) to the computer via nuDrive
However, the computer could not detect the nuDrive at all.
I found the PCI device in the NI MAX software but it showed a "PCI\VEN_1093&DEV_2CF0&SUBSYS_00000000&REV_01\4&38D01F93&0&30A4".
And because there was an exclamation point, I think it does not seem to be working properly.
(It said "Windows does not have a driver associated with your device.")
Also, the NI Device Monitor said that "No NI devices detected".
I think there would a problem regarding PCI device or nuDrive.
Would you please let me know how to overcome this situation?
Thank you so much.
I also attach a file about the above things.
(2,214 Views)
I'd make sure that you restarted your computer after installing the drivers and take a look at this article: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019RKoSAM&l=en-US
(2,073 Views)
