Digital I/O
Configuring Burst Protocol Input for Falling Edge PCLK
Using the 6534 card, is there a way to configure the NI card to recieve data using the Burst protocol on the falling edge of it's PCLK line? The default is the rising edge.
(3,214 Views)
Hello Matt,
Thank you for contacting National Instruments.
Try using the DIO Config.vi located under NI Measurements >> Data Acquisition >> Digital I/O >> DIO Config.vi. In the "handshaking mode parameters" cluster, set "edge mode" to trailing. I believe this will set your task to read on the falling edge of PCLK.
Let me know if you have any further questions.
Sincerely,
Sean C.
(3,209 Views)
