Digital I/O
Connecting Digital output of a sensor to Analog input.
I have connected the digital output of the PNP type sensor to Analog input in Single-ended mode. I am getting a Square wave.
Expected: Ideal case 0v should be obtained. When an obstacle crosses the sensor 10 V signal should come.
Actual     : Pulse waveform is obtained ideal condition and 10 V signal is obtained when the obstacle cross the sensor
Please help me to resolve the issue.
Anbarasan.
(1,589 Views)
Please post the waveform to understand better. Moreover, you can convert the analog signal into digital by applying thresholds for low and high.
Santhosh
Soliton Technologies
(1,556 Views)
