Digital I/O
Connecting PCI-6503 digital board with a PB24 mounting rack from Opto22
Dear Mr/Mrs,
I have a PCI-6503 digital board that I want to connect to a PB24 I/O mounting rack from Opto22. Is it possible to connect these two with just a NB1 Ribbon Cable or is any other contact needed as well? The mounting rack has a 50-pin card edge connector. Does the NB1 cable have an edge or a header contact? Does the NB1 cable fit right into the ditital board or is a CB-50LP Connector Block needed as well?
There are more information on the mounting rack at:
I attach a picture of the mounting rack connector as well.
Thank you in advance.
Best regards
/Karin Hellqvist
SWEP International AB
Message 1 of 1
(3,684 Views)
