Digital I/O
Connecting a NPN sensor to a DIO
Using a USB 6221 (or any std DAQ w/ DIO's) and want to connect an NPN sensor to activate a vi.  This will be to replace existing mechanical finger switches for ergonomic reasons.  The new sensor is an optical, no-touch switch.
Only vaguely familiar with transistor technology and am not sure how to make the connections.
The device I am trying to use is detailed here:  http://info.bannersalesforce.com/xpedio/groups/public/documents/literature/28436.pdf
It is the OTBVN6 model shown in the upper left of page 2 of this document.
The device requires a minimum of 10vdc so not sure what I need to do to connect it to a DIO.
Thanks for any input
Doug
Doug
"My only wish is that I am capable of learning each and every day until my last breath."
(4,490 Views)
Accepted by topic author dacad
Hi Doug,
You can use the attached schematic to connect your device to a digital input. You can use the n.c. or n.o. output.
The resistor will limit the maximum current to 10mA with a 10Vdc power connected to Vcc. If you connect the 5V from your DAQ device to the Vcc connection you can leave out the zenerdiode.
Kees
(4,474 Views)
I will give that a try.
I actually did get it to function with a DIO by connecting the NO to 5vdc from the DAQ and the NC to the DIO.  (This after I blew one of the DIO's, I can't help trying things....)
Not sure why this works bit will set up your option as it is probably a lot safer for the DAQ
Doug
Doug
(4,468 Views)
