Digital I/O
Connecting the SCB-100 to a Solid State Relay
Hey everyone,
I am trying to hook up a solid state relay to the SCB-100 which is connected to a PXI 6515 device. I was just wondering where I can purchase the connecting wire that is ideal for this purpose. A quick look online has yielded few helpful results. A link to grainger/zoro tools or others would be appreciated. The specifications are: The wire must be able to withstand 25V voltage, 25A current. It should also be easy to wire it into the SCB-100. Any AWG will do.
Thanks!
(5,628 Views)
Hi tompkins92,
Here is some information about AWG cables and their maximum current:
http://diyaudioprojects.com/Technical/American-Wire-Gauge/
Here is a place you might be able to purchase the appropriate wire:
 http://www.mouser.com/Wire-Cable/Hook-up-Wire/_/N-5ggs
You can select the voltage and current specifications you want.
I have one question: did you mean 25 mA current? Neither the SCB-100 nor the PXI 6515 can safely handle 25  amps.
https://www.ni.com/docs/en-US/bundle/scb-100-getting-started/page/scb-100-about.html
https://www.ni.com/docs/en-US/bundle/ni-651x-specs/resource/ni-651x-specs.pdf
Kelsey Johnson
http://www.ni.com/support
(866) 275-6964
(5,611 Views)
