Digital I/O
Connection between two or more outputs of PCI-DIO96
Is it allowed to connect an output with low-Signal and an output with high-Signal of PCI-DIO96. In the manual I found only, that it is not allowed to connect +5V to GND.
Thank you for your help
Markus Pilhoefer
(3,281 Views)
You shouldn't tie any two output pins together. If they have opposite polarity, the high output will attempt to drive the low output and may damage that port.
(3,281 Views)
