Digital I/O
Control a USB-6525 using Python
I am trying to control a USB-6525 using Python.  I have downloaded and installed the latest version of NI-MAX.  I also installed PyDAQmx.   However, it seems that there is a dependency that is probably not installed since I have minimal NI Hardware / Software installed in my machine.
The error I get: " Location of niDAQmx library and include file unknown on win32 - if you find out, please let the PyDAQmx project know"
I serched and the error is generated because there niDAQmx.h file is not present.   I found the following post:  http://digital.ni.com/public.nsf/allkb/FB26BDA52FFFD4EE86257124005C36C3?OpenDocument
However, there I cannot find an installation to install this examples.  Is there a location or an installation I can use to install those examples?
(6,150 Views)
What do you mean you downloaded latest NI MAX version?
http://digital.ni.com/public.nsf/allkb/F046BF3874E45BFF862574E2006EA83B
I would suggest you downloading DAQmx lastest version in case you don't have it yet:
http://www.ni.com/download/ni-daqmx-16.0.1/6471/en/
(6,073 Views)
Posting this in case it can help somebody with  a similar issue.
I had downloaded the latest version of NI-DAQmx.  However, after speaking with an NI support engineer.  It seems that that was the installer for only runtime version.
I was pointed to the NI-DAQmx installer for development.  Once that installation happen.  PyDAQmx runs quite well.
Rafael
(6,067 Views)
It was a pleasure, remember to Kudo the posts that are helpful and mark the posts as solutions to have an even better forum community!
(6,063 Views)
Hello.
I have searched for solutions where I can operate the USB-6525 with python. I guess I should need some kind of DLL-library. I was very surprised when the only thing is drivers at 1.8 Gb! Then is is not even obvious what I should install. Is there any easy to use DLL-library?
Kind regards
/Björn
(5,159 Views)
Hi Bjorn,
It looks as if this thread is pretty old. I would recommend creating a new thread with your question in order to receive more attention. In the meantime, please review the following link. Your answer may be found here.
http://www.ni.com/white-paper/53059/en/
Best of luck!
Austin
(5,143 Views)
