Digital I/O
Control of Pump using NI 6216
Using NI- 6216 and LabVIEW.
The pump has these control signals:
Start/Stop Contact input
0 or 5V
Direction: Clockwise/ Counter clockwise Contact input
0 or 5V
and Speed
0-1 V
My query is can you please let me the connections required from NI 6216 for contact input.
I assume a SPDT relay needs to be used. Can you show the required connections
(3,278 Views)
Accepted by topic author MysAnanth
I could figure this and is sorted out now. Since the signals are TTL controlling pin 3 and pin 1 with digital signals work. I was earlier wondering since the manual mentioned it as contact inputs.
(3,262 Views)
