Digital I/O
Controlling 3 LEDs
I am new user to labview. I am trying to control 3 LEDs (at the end solenoid valves) in order to have each of them switch on-off (at on=2 off=0.5 seconds), but each should start with a delay respect to previous one. So, I am trying to use the VI that I attached, and it works well to have 3LEDs on-off continuously till I stoped. I want to start each LEDs blinking with 0.5 delay respect to previous one. So, by applying this, the LEDs will flash at the same rate but with a time delay to each other. But unfortunately, the programm just turn on-off each of LEDs without any time overlap.
Could you please help me.
(6,286 Views)
I am not able to attach VI even any image.
(6,277 Views)
Try zipping up your code and posting that.
(6,272 Views)
I changed my  browser to Chrome
(6,186 Views)
I changed my browser to Chrome and now I can attach the file.
Apart from my goal to have an accurate control of On-Off time for 3 LEDs. To start having 3 LEDs witching On-Off in sequence, I tried with the VI attached to this post. But I do not know, how use data of true-false (boolean) of each frame for each LED and connect to DAQ assistant. I used Build array but it does not work.
I really apreciate your help.
(6,170 Views)
Since you only have 3 LEDs, I would just make an array to act as a lookup table for what your values should be.  You can then iterate the row circularly and index out the values to your LEDs.
(6,168 Views)
Thank you very much for your reply.
I will try to build a VI as you suggested. In my VI, I was able to control the On-time of LED, but I do not know how to implement this to your code.
In the meantime, I have another question regarding my first comment of this post. I have attached the VI that I am using, and as I mentioned I need to have a [t] second overlap (e.g. 500 s), between the same On-Off LED pattern. So, since the on-off time for all 3 LEDs are the same, with the delay, I can have an overlap between them. But I do not get what I expect, and each turn on-off after eachother with no overlap. Any guide will be appreciated.
(6,160 Views)
