Digital I/O
Custom SPI waveforms PXI-6551
v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } .shape { BEHAVIOR: url(#default#VML) } st1\:* { BEHAVIOR: url(#default#ieooui) } @font-face { font-family: Tahoma; } @page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.25in 1.0in 1.25in; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } A:link { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } A:visited { COLOR: purple; TEXT-DECORATION: underline } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline } SPAN.EmailStyle17 { COLOR: navy; FONT-FAMILY: Arial; mso-style-type: personal } SPAN.EmailStyle18 { COLOR: navy; FONT-FAMILY: Arial; mso-style-type: personal-reply } DIV.Section1 { page: Section1 }
Good day,
I would like to create a custom SPI waveform for the PXI-6551, where chip select (CS) is asserted in a pulse only after data is clocked out completely.
I've looked into a couple of possibilities:
1. SPI Digital Waveform Library - does not work for me! From what I read it has a fixed behavior for Chip Select(CS), in which CS is asserted during clocking of data.
2. Labview Signal Express - I see that to create a new signal I would need the Digital Waveform Editor(DWE) add-on.
Is there another way to do this that I am missing?
Su Gin
(3,556 Views)
you can just write one ore more U8/U16/U32- Arrays containing your actual bits to the PXI-6551
in order to achieve one/multichannel-pattern-output.
There are many examples which you can access in the LabVIEW-Example-finder, like
"Dynamic Generation of Multiple Waveforms.vi"
Marco Brauner NIG
(3,539 Views)
