Digital I/O
DAQ assistant aquisition rate
I am using the DAQ assistant to read in my digital 0-5V pulsed signal. It is pulsing at 80Hz. When I use the DAQ assistant it does not pick up all of the pulses. I am using a DAQ6251 card and a SCB-68 connector box. How do I check the aquisition rate of the DAQ assistant or am I using the wrong method to look at my digital pulsed signal?
many thanks
Message 1 of 1
(3,556 Views)
