Digital I/O
DAQ change detection function that returns a BCD to indicate which lines have had state changes
It was recommended to me to use the DAQ change detection function that returns a BCD to indicate which lines have had state changes. Does anyone know of this function, and it it is DAQmx or Traditional DAQ?
Thank you.
Danielle
(5,500 Views)
Danielle,
Check out this link which gives an overview of change detection using NI-DAQmx. It depends mostly on your hardware.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAn9SAG&l=en-US
Brad S. | National Instruments | CLA
(5,460 Views)
Hi Brad,
I saw that white paper before. I am just looking for the name of the method described above. I have a USB 6509. I am using C, not labview.
Best,
Danielle
(5,453 Views)
There are text based examples that install when you install DAQmx. They are located at Start » All Programs » National Instruments » NI-DAQ » Text-Based Code Support » ANSI C Examples » Digital » Read Examples. There will be examples on how to do change detection in C.
If they are not installed follow the instructions here to install them.
https://www.ni.com/en/support/documentation/supplemental/18/ni-daqmx-example-locations-for-labview-a...
Here is a link to the C Reference Help for DAQmx Functions
https://www.ni.com/docs/en-US/bundle/ni-daqmx-c-api-ref/page/cdaqmx/help_file_title.html
(5,435 Views)
