Digital I/O
DAQmx AO Series synch with DIO
There are not many DAQmx examples for the AO Series.
Can anyone supply me with an example of how to synchronize using DAQmx Analog Output on the master board with Digital Output/Input on a slave board?
I have an AO Series PCI-6723 (Dev1) and a DIO PCIe-6535B (Dev4) connected via a RTSI bus.  I have defined the RTSI cable using MAX and added both devices.
Haven't had any success, and cannot find an appropriate example.
I'm on a Windows 7 machine running Labview 2012.
Gretchen
(6,577 Views)
Hi, in general this article can be a great source. I also found a this example and another thread that discuss a similar issue. I hope this helps
Alejandro C. | National Instruments
(6,560 Views)
Hi, thanks for the info.  I had already studied White Paper on timing & synch, and found that example, but still having problems.
I get the following:
Error -89139 occurred at Voltage-Digital - Continuous Output 2 Devies.vi
Possible reason(s):
There are no shared trigger lines between the two devices which are acceptable to both devices. While each of these two devices support some shared trigger lines, none of these shared trigger lines work for both devices for the specified property and corresponding value.
Consider routing the signal through the I/O connectors of the two devices, if applicable.
Source Device: Dev1
Destination Device: Dev4
I have attached my Sample VI.  You will see that I basically took two examples from Example Finder and combined them.
There is a RTSI cable connecting the two devices.  I don't get an error until DAQmx on the digital device.
Do I need to EXport Route VI?
Gretchen
(6,539 Views)
This error appears when: 1. routes are reserved by another program (fix»reset device from MAX), 2. You are trying to create a route on the device that is not supported (fix»modify the code to change the device routes to those supported).
I hope this helps
(6,531 Views)
I looked over the example, and even though I do not have an E Series, S, M, DSA, etc, I thought I'd try anyway.
Attached is my modified version.  My analog output device, PCI-6723 is an AO Series, and my DIO device, PCIe-6535B is ..... I'm not really sure - X series???
I get the following error:
Error -200452 occurred at Property Node DAQmx Timing (arg 1) in Multi-Device Synch-Analo-Digitalg Output.vi
Possible reason(s):
Specified property is not supported by the device or is not applicable to the task.
Property: RefClk.Src
Oh, I also tried your 1st solution - to reset devices using MAX.  but I still get errors.
I have tried Export Signal VI; I have tried DAQmx Connect Terminals VI.  Still no luck.
On Monday, I will try using a route through Counter0 on master device.
G
(6,518 Views)
Accepted by topic author GretchenSkellyZimmer
I came up with a solution!  It's complex, but it seems to work.
I used DAQmx Export Signals VI & DAQmx Connect Terminals VI.
See attached VI.
Gretchen
(6,488 Views)
