Digital I/O
DAQmx DOChannel.OutputDriveType Push-pull Mode
I simply don't understand how to change the setting of the port to Active Drive or to Open Collector.
Where does the DOChannel.OutputDriveType is applied in this simple creation of a writen task ?
if (DaqSystem.Local.Devices.Length == 0) return;
            try
                using (Task digitalWriteTask = new Task())
                    //  Create an Digital Output channel and name it
                    //digitalWriteTask.DOChannels.CreateChannel("Dev1/port2/line3", "TimeOutWhite", ChannelLineGrouping.OneChannelForEachLine);
                    sLine = string.Format("{0}/{1}/{2}", sNameDevice, "port2", "line3");
                        sLine,
                        "TimeOutWhite",
      DigitalSingleChannelWriter writer = new DigitalSingleChannelWriter(digitalWriteTask.Stream);
             writer.WriteSingleSampleSingleLine(true, !boAff);
(4,463 Views)
Hi Fred1204,
The OutputDriveType is a property, so you have to set
digitalWriteTask.DOChannels.All.OutputDriveType = DOOutputDriveType.ActiveDrive;
or
digitalWriteTask.DOChannels.All.OutputDriveType = DOOutputDriveType.OpenCollector;
The output drive type of the NI-USB 6008 is always open-drain and cannot be changed to push-pull.
Please don't hesitate to get in contact with me by responding to this post
Best regards
Benjamin
(4,448 Views)
