Digital I/O
DAQmx synchronize digital input and digital output task
Hello.
I need to synchronize digital input and digital output on NI6229 or NI6535 device, for emulating i2c-like protocol receiver.
Looks like only way - use PXI_Trig or PFI lines for synchronize tasks start, but if I don't understand how to do it without hardware modifying.
bool CheckAck(const char *devDataLine, const char *devClockLine, bool *ackReceived)
//Data, Clock - low
//Clock high
//Data high
int32 error;
TaskHandle clkHandle = 0;
TaskHandle dataHandle = 0;
bool result = true;
int32 samples_written;
int32 samples_readed;
int32 bytes_per_sample;
uInt8 clock_out[] = {
0,
0,
1,
1,
0,
0,
uInt8 data_in[sizeof(clock_out)];
samples_written = 0;
samples_readed = 0;
DAQmxErrChk(DAQmxCreateTask("", &clkHandle));
DAQmxErrChk(DAQmxCreateTask("", &dataHandle));
DAQmxErrChk(DAQmxSetDOLogicFamily(clkHandle, "", logic_family));
DAQmxErrChk(DAQmxSetDILogicFamily(dataHandle, "", logic_family));
DAQmxErrChk(DAQmxCreateDOChan(clkHandle, devClockLine, "", DAQmx_Val_ChanPerLine));
DAQmxErrChk(DAQmxCreateDIChan(dataHandle, devDataLine, "", DAQmx_Val_ChanPerLine));
DAQmxErrChk(DAQmxCfgSampClkTiming(clkHandle, "", (double)i2c_clk, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, sizeof(clock_out)));
DAQmxErrChk(DAQmxCfgSampClkTiming(dataHandle, "", (double)i2c_clk, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, sizeof(clock_out)));
DAQmxErrChk(DAQmxWriteDigitalLines(clkHandle, sizeof(clock_out), 0, 10.0, DAQmx_Val_ChanForAllLines, clock_out, &samples_written, NULL));
DAQmxErrChk(DAQmxReadDigitalLines(dataHandle, sizeof(data_in), 10.0, DAQmx_Val_ChanForAllLines, data_in, sizeof(data_in), &samples_readed, &bytes_per_sample, NULL));
DAQmxCfgDigEdgeStartTrig(clkHandle, "PXI_Trig0", DAQmx_Val_Rising);
DAQmxCfgDigEdgeStartTrig(dataHandle, "PXI_Trig0", DAQmx_Val_Rising);
DAQmxErrChk(DAQmxStartTask(clkHandle));
DAQmxErrChk(DAQmxStartTask(dataHandle));
//how to software trigger PXI_Trig?
DAQmxErrChk(DAQmxWaitUntilTaskDone(clkHandle, 10.0));
error:
if (error_log)
if (DAQmxFailed(error))
char descr[1024];
DAQmxGetErrorString(error, descr, sizeof(descr));
printf("%s\n", descr);
if (clkHandle != 0)
DAQmxStopTask(clkHandle);
DAQmxClearTask(clkHandle);
if (dataHandle != 0)
DAQmxStopTask(dataHandle);
DAQmxClearTask(dataHandle);
return result;
Message 1 of 1
(1,040 Views)
